Removed from a 1973 240Z.  VIN HLS30-1630XX
Buyer pays $5.00 USD + shipping from zip code 23462
Miscellaneous engine bay brake/clutch tubing clips, fasteners and seriously hard-as-brick-rubber isolators. Some are broken.
If the rubber bricks are not needed, they can be tossed prior to shipping. I will not remove the rubber from clips that will need to be bent to remove the isolator.
Yes, there are seven clips but only five fasteners. If you have done this before, you KNOW where the other two went....
Dibs to first to respond to this thread THEN PM me. Thanks in advance for helping me clean my garage out.
Wayne
  • 3 weeks later...
