Posted June 6, 20178 yr comment_522436 while tuning my 3 screws round top su carbs this weekend after setting the timing to 14 btdc, i found out that even if i turn the fuel mixture knob 5 turns clockwise when i raise the piston the engine shuts down. Could the float level in this rear carb be wrong? It does not happen on the front carb. My tuning procedure starts at 2.5 turns clockwise (lowering the jet 2.5 turns). After that i set the idle rpm at 1000 RPM and doublé check the air with the synchometer. Then i turn the fast idle screw until it hits 3000 RPM on the tachometer and verify the balance amongst both carbs with the synchometer. i tend to increase the fuel mixture knob to 3 turns each depending on the gunson colortune. Is there something i am not doing correctly? Valves have been perfectly adjusted. Link to comment https://www.classiczcars.com/forums/topic/57871-3-screws-round-top-su-carb-tuning-correct-or-not/ Share on other sites More sharing options...
June 6, 20178 yr comment_522437 Try the piston lift experiment but with the engine at 2000rpm (use the fast idle screw in the middle of the carb linkage to get the 2000 rpm). If both carbs are getting the same air and same fuel, the rpm drop should be the same when you lift a piston. Note: 1. SU's are air balanced at idle using the stop screws on each side of the carb and a flow meter. 2. SU's are air balanced at 2,000 to 3000rm using the screw in the linkage near the back carb (the back carb's air is matched to the front carb). 3. The fuel is matched by jet height and needle shape. Link to comment https://www.classiczcars.com/forums/topic/57871-3-screws-round-top-su-carb-tuning-correct-or-not/#findComment-522437 Share on other sites More sharing options...
June 6, 20178 yr comment_522443 240260280 is on point above. One thing I would recommend is using an aftermarket tachometer or dwell/tach to ensure you know your true engine speed when doing any tuning. These are easy to hook up and allow you to see the engine RPM's while working under the hood. The original tachs in our cars seem to suffer from a little to sometimes a lot of inaccuracy. Link to comment https://www.classiczcars.com/forums/topic/57871-3-screws-round-top-su-carb-tuning-correct-or-not/#findComment-522443 Share on other sites More sharing options...
June 6, 20178 yr Author comment_522449 thanks! ill set my rpm to 2000 with the fast idle screw and check to see if when i lift the piston the engines shuts down. Link to comment https://www.classiczcars.com/forums/topic/57871-3-screws-round-top-su-carb-tuning-correct-or-not/#findComment-522449 Share on other sites More sharing options...
June 6, 20178 yr comment_522457 2000 is just a ball park to give the engine a bit more air and speed. Go as high as you feel comfortable with. The key is to make sure they have the same air flow then adjust the fuel jet height to make sure they each drop to the same RPM. It is iterative so you have to repeat a few times to get it dialed in. Edited June 6, 20178 yr by 240260280 Link to comment https://www.classiczcars.com/forums/topic/57871-3-screws-round-top-su-carb-tuning-correct-or-not/#findComment-522457 Share on other sites More sharing options...
June 6, 20178 yr comment_522459 4 hours ago, Hardway said: 240260280 is on point above. One thing I would recommend is using an aftermarket tachometer or dwell/tach to ensure you know your true engine speed when doing any tuning. These are easy to hook up and allow you to see the engine RPM's while working under the hood. The original tachs in our cars seem to suffer from a little to sometimes a lot of inaccuracy. I agree. A great tool is a timing light with built-in tach. and advance. I use mine all the time. Edited June 6, 20178 yr by 240260280 Link to comment https://www.classiczcars.com/forums/topic/57871-3-screws-round-top-su-carb-tuning-correct-or-not/#findComment-522459 Share on other sites More sharing options...
June 7, 20178 yr Author comment_522478 Is there any more effective way to adjust the right amount of turns of the fuel mixture knobs other than using the gunson colortune? I know you start at 2.5 turns clockwise and then keep lowering the jets. Link to comment https://www.classiczcars.com/forums/topic/57871-3-screws-round-top-su-carb-tuning-correct-or-not/#findComment-522478 Share on other sites More sharing options...
June 7, 20178 yr comment_522480 Air/Fuel O2 measurement is best method. Link to comment https://www.classiczcars.com/forums/topic/57871-3-screws-round-top-su-carb-tuning-correct-or-not/#findComment-522480 Share on other sites More sharing options...
June 7, 20178 yr Author comment_522493 Which is this method? Colortune method? Link to comment https://www.classiczcars.com/forums/topic/57871-3-screws-round-top-su-carb-tuning-correct-or-not/#findComment-522493 Share on other sites More sharing options...
