Skip to content
Smog Fail - headers and EGR
  • 3 weeks later...
Hi guys/gals,
Just wanted to give you a quick update on my transition so far. I did take my car to a specialist where they did install a OEM exhaust manifold along with a new fabricated down pipe. Here is the thing, When I got the car back, I noticed the car was over heating. We are talking about the car reaching 250 degrees. My meter was pushing far right and I was so confused. Then I remembered that I saw liquid stains over my cap and rotors. Turns out when they displaced my intake manifold, they had to dump of radiator fluids out. So... I filled it back with radiator fluid. Not too happy with this mistake. So far, I did install the EGR apparatus. I am awaiting for the transducer and EGR control valve.
My concern is the smog specialist said that the "3 way rocker rubber hose," that came from the engine block and connected to my air flow meter hose, was not smog compliant. Is this true? I find this questionable and wanted to ask you folks on this.
Read this thread, it might cover it.  http://www.classiczcars.com/forums/topic/56054-afm-to-tb-boot-no-port/
The smog tech might have access to the recall bulletins.  Check the hood for a sticker, it might have a number on it.  If it does, post the number in the other thread so we can Google it
Keep an eye on the temperature gauge.  These engines like to blow head gaskets after overheating, due to head warpage.  Hope yours didn't get that hot.  The shop screwed up big time by not topping off the coolant after spilling some.  They should have known better.
  • 3 weeks later...
Edited by darom
font too large for posting
