Posted May 10, 20169 yr comment_494687 I've got a factory remote oil cooler from a ZX turbo on my Z but one of the fittings between the mount and the radiator is leaking so I need to remove it and repair it. I didn't mount it on the car and am curious if the threaded fitting on the block is still there so I can remove all of the oil cooler components and just screw the oil filter back on to the block or was it removed to put the remote mount on. Any help would be appreciated. Link to comment https://www.classiczcars.com/forums/topic/55434-zx-turbo-remote-oil-cooler-question/ Share on other sites More sharing options...
May 10, 20169 yr comment_494697 You should be able to remove the adapter for the oil cooler where the stock filter mounts, to bypass the cooler. You might need to re-install the oil filter stud, I don't remember if it is removed to fit the adapter on. Link to comment https://www.classiczcars.com/forums/topic/55434-zx-turbo-remote-oil-cooler-question/#findComment-494697 Share on other sites More sharing options...
May 11, 20169 yr Author comment_494703 Thats what I was wondering myself, is the stud still there. I don't think it is because the adapter bolts on to the block and I don't have a stud readily available.. Edited May 11, 20169 yr by gogriz91 Link to comment https://www.classiczcars.com/forums/topic/55434-zx-turbo-remote-oil-cooler-question/#findComment-494703 Share on other sites More sharing options...
May 11, 20169 yr comment_494731 The threaded stud is available from Zcardepot, or probably a Nissan dealer. Link to comment https://www.classiczcars.com/forums/topic/55434-zx-turbo-remote-oil-cooler-question/#findComment-494731 Share on other sites More sharing options...
May 11, 20169 yr Author comment_494757 I've got one on order, thanks for the lead. Link to comment https://www.classiczcars.com/forums/topic/55434-zx-turbo-remote-oil-cooler-question/#findComment-494757 Share on other sites More sharing options...
