Recommended silent and powerful Electric Fuel Pump for a modified 240z
The fuel pump in my car is faulty it is just reaching 0.8 psi and 1.5 p.si at low rpm. post-29967-1415083014218_thumb.jpg
I am planning on replacing it. This car has a L24 motor with crank and rods from a L26, special oversized 84mm flat top black coated pistons from D.L. Potter Engineering with E88 Head and Far 311 New Race Cam which makes this motor 79 mm stroke instead of the stock 73.7 mm
stock bore is 83 mm for the L24 and the L26 motors. This block has been bored out 1 mm to compensate for wear and makes my motor a 2.627 liter motor.
In view of the above i need a powerful and silent Electric Fuel Pump. I read the electric fuel pumps for Mazda RX7 are the ones recommended? Any other opinions?
Mallory Comp 110 or higher. Much much quieter than any Holley pump. Not cheap. Use on my street 3,2L 240Z. Have Holley Blues on the race car because once the car is started you can't hear sh#t.
http://www.summitracing.com/int/search/product-line/mallory-comp-pump-fuel-pumps
Summit advertises several models which one is the best for my car? I want perfect and powerfull flow for my car.
