What is the correct fuel hose size going from tank to G2 fuel filter then to airtek electric pump then to supply line. I have 1/4 going from supply line under hood to the fuel rail.
I searched everywhere and cant find the answer. Right now I have 3/8 which is too big on those 3 sections.
https://www.classiczcars.com/forums/topic/48792-fuel-supply-line-hose-size/
It's not easy to get the hose clamped to the hard line without a lift, so maybe use marine grade USCG fire-rated hose, with a liner to prevent ethanol from wrecking it. Expensive but you don't need much. Might only need to do it once.
