Skip to content
Coilovers and brake question
Bit off topic, but putting the lower control arm on, do you just place the big bush in the crossmember and slide the spindle through? No washer between bush and crossmember?
Just seems to be tight, like it doesn't freely move up and down easily. I'm greasing all the nolathane with molygrease
it certainly does mate cheers! one thing tho, would you be able to tell me what #19 is?
putting this car back together i need one of these cd's!
Edited by tez240k
Hmm just looks odd. I've got nolathane bushes. I thought you have a bush on each side, the pin in the centre, two washers and a nut? But looks like there's something else
ok i just read that VT v6 calipers are a direct bolt on to the 240K strut?? that would seem alot easier and i can get a pair of them for nothing quite easily! this true?! or sumitomos still better?
Any word if they are interchangeable?
nah not too sure. from what i read you still need to run the thicker disk with them. But i ended up picking up a set of struts with sumis and new shock inserts
