I thought the antenna drain grommet, inner fender seals and cowl drain grommets were well tucked away... but did you know a small rubber lives inside the door and is a rest for the window when fully lowered?
Here it is and also where it goes:
See the bracket/stand-offon the bottom of the door with the rectangular hole? That is where in mounts.
Another shot:
I saw a photo of a rubber wire-tied there but I cna not find it now.
https://www.classiczcars.com/forums/topic/41069-most-hidden-rubber-part/
And it attaches to that stand through a hole, using one of the same metal clips that attaches the door panels to the door on 240's. Really fun to get in place. I've been known to put a sticky back rubber thing from the hardware store....
  • 4 weeks later...
