Well in the process of trying to replace all my front end bushings I ran into a prob with my LCA bolt being totally seized to the sleeve. Tried everything including heat with no success. In short I was forced to cut the bolt off now I can't find a replacement. Anyone know where I can get one or does anyone here have an extra pair for sale?
The shop replacing the bushings on my '73 had the same problem, and the bolts had to be cut off. He replaced them with new bolts from McMaster-Carr which are 14mm x100mm length x 2mm pitch. The part number is 95327A745
Peter
So it looks like $6.50 + S/H But at least Greentrees got OEM bolts and Nuts, I didn't look to see how much the nuts were. But I'm sure it went over what I charged Greentrees.
My only advice is invest in a can of Anti-Seize, coat EVERY bolt that you reinstal in your 240Z. Not a single bolt on my car is without a little Anti-seize. LOVE LOVE LOVE that stuff.
Your quite welcome BTW.
My pleasure,
Dave
Just got the bolts in today! Looks to be in great shape. I've got my anti-seize lube, ready to knock it out tmrw. Hopefully it'll all go well. Muchos Garcias! LOL
Thanks for the heads up Pete. Glad to know I wasn't the only one with the problem. Hopefully the shop didn't accidentally cut into your crossmember like I did in the process. Smh...
