hi all,
haven't started the 240z in approximately 2 months (vacation and busy with other projects)...i tried starting it the other day...engine wants to turn over but doesn't start...thought it was the battery..replaced it, but the car still doesn't start...any suggestions/help would be greatly appreciated....
https://www.classiczcars.com/forums/topic/36955-car-wont-start/
Fuel, air & spark. If the engine is turning over, one of the three is missing.
For an engine that didn't have a pre-existing problem when it was parked 60 days ago, my first guess would be fuel.
I don't know anybody else here but with the guys I came up with, turning over means the starter is turning the engine rotating assembly. If the crank ain't turning then it isn't "turning over" ;)
  • 1 month later...
ditto: engine needs fuel, spark, compression. So you have DC, ok now check for spark at the spark plugs, if ok then check fuel (is you're tank full? do you have fuel at the cabs ect) than compression, this you would check last. :paranoid::stupid:
