Skip to content
Loud Clunking Noise Upon Putting In Reverse
When i put my 1983 280z in reverse i hear a loud clunk from the rear of the car i dont think it is the gears but a mount of some sort any ideas????.
1. Diff mount shot
2. Diff strap shot
3. Half shaft universals shot
I'd place a bet on the mount and strap being stuffed. Cheap to replace and not to hard either. Get them from MSA and fit them yourself.
Chaddy, if you put a floor jack under the diff. and watch it when you raise the car, it it moves first before the car starts to rise. It is the diff mount. It could be the u-joints also, so have a close look at them . There should be zero play in the u-joints. Gary
1. Diff mount shot
2. Diff strap shot
If you know the OEM part numbers they're about $20 cheaper each than MSA or Courtesy Nissan. here
OK guys, the car is a 83 280ZX NA.
http://www.blackdragonauto.com/icatalog/z/t.asp?page=90
I have no idea how to fix the clunk in the rear end of a ZX, so if any of you can help this guy out then go for it.
But from what I see from the above link, part 59 could the issue.
It looks like the S130 had a better mounting setup than the S30. No strap and what appears to be an easier to change insulator.
