Posted July 26, 200718 yr comment_216552 I noticed an area where the paint looks like it is starting to crack on my roof. Apparently I didn't sand well enough during prep. Does anyone know of a good compound or wax I can buff into it, so I can "hide" it till garage season and get it done right? It's hard to see, but I know it is there and it is driving me nuts!Thanks all. Link to comment https://www.classiczcars.com/forums/topic/25026-paint-cracking/ Share on other sites More sharing options...
July 26, 200718 yr comment_216556 Where is the crack? It's common to have cracks on both sides where the roof panel is joined to the quarter panel. Link to comment https://www.classiczcars.com/forums/topic/25026-paint-cracking/#findComment-216556 Share on other sites More sharing options...
July 26, 200718 yr comment_216558 Good tip Mike - I have been trying to figure why my car has touch up paint on both sides around there, hard to imagine damage on both sides? - Question answered.Later Link to comment https://www.classiczcars.com/forums/topic/25026-paint-cracking/#findComment-216558 Share on other sites More sharing options...
July 26, 200718 yr comment_216565 That particular problem is caused by the factory joint using lead solder. When the body of the car flexes the paint cracks. My body guy removed the lead and replaced it with a modern panel bond adhesive. Here's an old thread that describes the problem better than I can:http://www.classiczcars.com/forums/showthread.php?t=6190 Link to comment https://www.classiczcars.com/forums/topic/25026-paint-cracking/#findComment-216565 Share on other sites More sharing options...
July 26, 200718 yr Author comment_216601 middle of the roof unfortunately. Link to comment https://www.classiczcars.com/forums/topic/25026-paint-cracking/#findComment-216601 Share on other sites More sharing options...
July 28, 200718 yr comment_216751 I'd like to see an answer posed, as well. The pass. door has all kinds of crackling paint, but the paint won't flake off. Link to comment https://www.classiczcars.com/forums/topic/25026-paint-cracking/#findComment-216751 Share on other sites More sharing options...
July 28, 200718 yr comment_216775 Cracking ... or .... crazing?A crack is just that, a visible break in the paint. Sometimes in a straight line and sometimes in a curve but generally with a distinct edge to it's edge.Crazing on the other hand, can look like cracking, except now it starts to look more like shattered safety glass. That is, a cross-hatch pattern composed of various "lines" of cracks that criss-cross each other in irregular pieces but mostly rectangular shaped (or an angled parallelogram).Cracking is generally caused by flexing of the sub metal or joint and the paint not flexing to the same degree.Crazing on the other hand is usually indicative of a poor prep job prior to paint. Causes can be body oils, poorly cured red-cap or too thick primer or some other incompatibility with the base primer or filler or... Cracking can sometimes be masked by careful application of touch up paint.Crazing can also be masked with touch up paint, but usually will craze again.Crazing can also look like a stress crack on the paint on a rubber bumper.FWIWE Link to comment https://www.classiczcars.com/forums/topic/25026-paint-cracking/#findComment-216775 Share on other sites More sharing options...
July 28, 200718 yr Author comment_216783 I think I'm riding the crazing train. Link to comment https://www.classiczcars.com/forums/topic/25026-paint-cracking/#findComment-216783 Share on other sites More sharing options...
