Skip to content
Combination switch
Can anyone tell me where I might find a cheap, good combination/turn signal switch. This seems to be the last thing to get my 260 to pass inspection. I have done some searching but can't really seem to find anything outside of ebay. I really can't wait for the bidding to end so please help!
Have you tried cleaning the existing one up up to get it working? I believe there are some threads on here baout that, and at least one that discusses refurbished units which are available. Use the search feature and see what you can find.
Around $50 or so would be good I guess, it depends on quality I suppose. And I tried cleaning it up but it's something inside that's causing the problem. I used a chart from an earlier post to check continuity throughout the switch.
  • 1 month later...
I'm having a lot of problem with dash gauges (all excepy speedo) dome light, my stock fuel pump relay(alternator) and the yellow wire to the alernator and a few other things and I've been tolk that All these problems are stemming from my combo switch (turn/dimmer/horn)side, turn signals.I even have a few melted connectors 1. 9prong @ combo switch
2. hazzard switch 3. flasher unit. I'm being told that all the problems are stemming from the combo switch, does that sound right to you guys?
DeeDee
