July 5, 200619 yr comment_173449 I thought someone had done write up on this?Anyone tried search? Link to comment https://www.classiczcars.com/forums/topic/20593-map-light/?&page=2#findComment-173449 Share on other sites More sharing options...
July 5, 200619 yr comment_173459 Found it!Zs-ondabrain is the man! Link to comment https://www.classiczcars.com/forums/topic/20593-map-light/?&page=2#findComment-173459 Share on other sites More sharing options...
July 5, 200619 yr comment_173461 He and others are working on LED replacements for the outside lights, and for the guages. The problem with LEDs is that they are too focused, and would make better lamps for a flashlight than something to illuminate a wide area like the guage faces or the area under the map light. You'd need a row or two of closely-spaced LEDS for something like the map light. Link to comment https://www.classiczcars.com/forums/topic/20593-map-light/?&page=2#findComment-173461 Share on other sites More sharing options...
July 5, 200619 yr comment_173462 Check out this thread.http://www.classiczcars.com/forums/showthread.php?t=15179&highlight=led+lightsHe specificaly mentions and shows his prototype for the map light.Haven't heard anymore since then, perhaps he can enlighten (no pun intended) us.... Link to comment https://www.classiczcars.com/forums/topic/20593-map-light/?&page=2#findComment-173462 Share on other sites More sharing options...
July 5, 200619 yr comment_173473 Thats what a diffuser does Link to comment https://www.classiczcars.com/forums/topic/20593-map-light/?&page=2#findComment-173473 Share on other sites More sharing options...
July 6, 200619 yr comment_173696 www.maglite.comHaha Link to comment https://www.classiczcars.com/forums/topic/20593-map-light/?&page=2#findComment-173696 Share on other sites More sharing options...
July 7, 200619 yr comment_173712 You can buy an LED substitute for the incandescent bulb in a Maglight or Mini Maglight. From using my Faraday flashlight, I'll bet that the LEDs are pretty bright and focused and you could probably leave the light on all night and still have enough battery left for the next night. Link to comment https://www.classiczcars.com/forums/topic/20593-map-light/?&page=2#findComment-173712 Share on other sites More sharing options...
July 13, 200618 yr Author comment_174448 Thanks everyone for your thoughts and advice. I'm very intrigued by the LED's, damn our lighting is . . . lacking!!! However, sadly I find myself bitten by the bug, constantly looking @ Ebay, searching for info on this and that, "Hello my name is Jim and I'm "Z" addicted" . . . sigh!!! Link to comment https://www.classiczcars.com/forums/topic/20593-map-light/?&page=2#findComment-174448 Share on other sites More sharing options...
July 13, 200618 yr comment_174536 You have to make the led map light your self Link to comment https://www.classiczcars.com/forums/topic/20593-map-light/?&page=2#findComment-174536 Share on other sites More sharing options...
July 14, 200618 yr comment_174544 I have an extra one. it's from a 280z,78 Link to comment https://www.classiczcars.com/forums/topic/20593-map-light/?&page=2#findComment-174544 Share on other sites More sharing options...
July 14, 200618 yr comment_174616 Hello suzook86,I have a map light from a '71. Its not in pristine condition and one of the wires has had the original connector replaced with a crimp on but it is serviceable. I got a nice one when I replaced my dash. I also have the original flat bezel without the hood if you are interested.Best,H HoughtonPS I'm just up the hill from you in Santa Fe Link to comment https://www.classiczcars.com/forums/topic/20593-map-light/?&page=2#findComment-174616 Share on other sites More sharing options...
