This will drive you bananas! 21.71 seconds was my best time.
It's harder than it looks.
Try this ..
The object of the game is to move the red block
around without getting hit by the blue blocks or
touching the black walls.
If you can go longer than 30 seconds you are phenomenal.
The US Air Force uses this for fighter pilots.
They are expected to go for at least 2 minutes. Give it a try !!
click here: http://tinyurl.com/56t9u
https://www.classiczcars.com/forums/topic/18732-try-this/
The only problem is that this particular link the blue blocks aren't random they move the same way every time you play so you can just get used to a pattern (ie. pacman)...but if you were tested on the first try and got to 2 minutes, man you are the stud...cause I sure didn't.
https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154227
42.156 This was after about an hour and a half and 5 college guys betting every last dime they have seeing who is the best!!! So far I win, but i'm sure this will go on for atleast another 5 or 6 hours!! LOL who needs sleep anyway? I swear after 30 sec. its all luck, and you pray your palms dont start to get sweaty and loose grip!!!LOL
https://www.classiczcars.com/forums/topic/18732-try-this/#findComment-154236
