Trying to find out what part is misssing on my spare set of SU carbs What is missng and what does it do !!!!!!
could you be a little more specific? Pictures? How about Clue, at least.
Having trouble getting up pictures !!! Try to upload them later tonight !!! Thanks for the quick response !!! I have the carb on my desk took the pictures and that where am at !!!! I will try again later !!!!
Go to ZTherapy's excellant site and look through their pics. Or try Datsun's part listings. It it might be hard to figure out what's missing as opposed to what something is from any pics you post, however.
Looks like a front carb off a 70/71 240Z. No water passages like on the '72 carbs. The spot were the pencil is inserted most likely had a set screw (idle limiter) mounted in it to limit the downward travel of the idle adjust nut. I've got one set of the early carbs that still have the idle limiters, but they are missing from the other set of carbs that I have. Nothing that will affect the operation of the carb. Also, mine have the old screw type spring clamps on the rubber hose that connects the float bowl to the fuel nozzle.
I can't tell from the angle of these shots, but I don't see the suction chamber that is on the top of the carb. It houses the suction piston and damper.
