Posted June 3, 200223 yr comment_8201 hey all im looking for both the tank and carbs both used and cheap lemi know all thnx. Link to comment https://www.classiczcars.com/forums/topic/1826-71-240z-gas-tank-and-triple-webers/ Share on other sites More sharing options...
June 3, 200223 yr comment_8231 make offer on the tank and i have a set of tripple dell ortos 40mm that are easier then webers on the adjustments and the mileage. the tripples are 400 obo. or ill do this if you give me 400 ill just give you the tank with the carbsjames Link to comment https://www.classiczcars.com/forums/topic/1826-71-240z-gas-tank-and-triple-webers/#findComment-8231 Share on other sites More sharing options...
June 3, 200223 yr comment_8235 I have a gas tank (both the large and small). how's $25?Michael Link to comment https://www.classiczcars.com/forums/topic/1826-71-240z-gas-tank-and-triple-webers/#findComment-8235 Share on other sites More sharing options...
June 3, 200223 yr comment_8236 did only the 70-1s have smaller gas tanks? (how much smaller are they if i may ask)...-e Link to comment https://www.classiczcars.com/forums/topic/1826-71-240z-gas-tank-and-triple-webers/#findComment-8236 Share on other sites More sharing options...
June 3, 200223 yr comment_8244 Oh mine's from a 73, and meaning smaller on I meant the one that connects right up by the filler hole. They're both off the same car and in good shape. I don't know what year models are the same or different. Link to comment https://www.classiczcars.com/forums/topic/1826-71-240z-gas-tank-and-triple-webers/#findComment-8244 Share on other sites More sharing options...
June 3, 200223 yr Author comment_8262 hey can you give me like a day to think it over on the carbs so i can research them a little bit but 90%chances are that ill buy them ok? thnx dude a teacher at my school worked for nissan z's only so he will be able to help me out thnx again dude Link to comment https://www.classiczcars.com/forums/topic/1826-71-240z-gas-tank-and-triple-webers/#findComment-8262 Share on other sites More sharing options...
June 4, 200223 yr comment_8264 just let me know and ill set it all aside Link to comment https://www.classiczcars.com/forums/topic/1826-71-240z-gas-tank-and-triple-webers/#findComment-8264 Share on other sites More sharing options...
