January 18, 200619 yr Author comment_152406 Here's another spreadsheet I currently have done that can be posted for general use by all concerned....Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...webdawg1Fiche 65-1 Side Marker Lamp.xls Link to comment https://www.classiczcars.com/forums/topic/17680-restoration-spreadsheets/?&page=5#findComment-152406 Share on other sites More sharing options...
January 26, 200619 yr Author comment_153481 Here's another spreadsheet I currently have done that can be posted for general use by all concerned....Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...webdawg1Fiche 103-1 Steering Wheel (From Aug '73).xls Link to comment https://www.classiczcars.com/forums/topic/17680-restoration-spreadsheets/?&page=5#findComment-153481 Share on other sites More sharing options...
January 26, 200619 yr comment_153508 Thanks webdawg these will come in handy. Link to comment https://www.classiczcars.com/forums/topic/17680-restoration-spreadsheets/?&page=5#findComment-153508 Share on other sites More sharing options...
February 9, 200619 yr Author comment_155200 Here's another spreadsheet I currently have done that can be posted for general use by all concerned....Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...webdawg1Fiche 97-1 (Brake & Clutch Pedal).xls Link to comment https://www.classiczcars.com/forums/topic/17680-restoration-spreadsheets/?&page=5#findComment-155200 Share on other sites More sharing options...
February 19, 200619 yr Author comment_156609 Here's another spreadsheet I currently have done that can be posted for general use by all concerned....Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...webdawg1Fiche 139-1 Tail Gate Window (From Aug '73).xls Link to comment https://www.classiczcars.com/forums/topic/17680-restoration-spreadsheets/?&page=5#findComment-156609 Share on other sites More sharing options...
March 9, 200619 yr Author comment_158653 Here's another spreadsheet I currently have done that can be posted for general use by all concerned....Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...webdawg1Fiche 37-1 Air Cleaner L28E (From Dec 74').xls Link to comment https://www.classiczcars.com/forums/topic/17680-restoration-spreadsheets/?&page=5#findComment-158653 Share on other sites More sharing options...
March 30, 200619 yr Author comment_161663 Here's some more spreadsheets I currently have done that can be posted for general use by all concerned....Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...webdawg1Fiche 42-1 Water Pump & Fan Belt L28E (From Dec '74).xlsFiche 71-1 Clutch Disc, Clutch Cover & Drawal Lever.xls Link to comment https://www.classiczcars.com/forums/topic/17680-restoration-spreadsheets/?&page=5#findComment-161663 Share on other sites More sharing options...
June 16, 200619 yr Author comment_171160 Have not posted anything for a while....working on the house quite a bit lately...(Long story) thought I would throw out just a simple little spreadsheet to help track the progress with part ordering and that sort of stuff. Change the headings to what ever you would like to put in there to suit your own needs. Kind of helps when you have all your part numbers, and other miscellaneous data all in one place when you go by the dealership to order parts...etc...etc.webdawg1Parts Needed (Blank).xls Link to comment https://www.classiczcars.com/forums/topic/17680-restoration-spreadsheets/?&page=5#findComment-171160 Share on other sites More sharing options...
February 23, 200718 yr Author comment_200258 Here's another spreadsheet I currently have done that can be posted for general use by all concerned....Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...webdawg1Fiche 170A-1 (Emblems From Dec '74).xls Link to comment https://www.classiczcars.com/forums/topic/17680-restoration-spreadsheets/?&page=5#findComment-200258 Share on other sites More sharing options...
June 30, 200717 yr Author comment_213741 Have not posted anything for a while....Here's another spreadsheet I currently have done that can be posted for general use by all concerned....Remember to make any changes to the spreadsheet(s) based on your model year (I.E. - 240, 260, 280) as there will be "some" differences between model years...but for the most part should be pretty accurate...It also helps if you have the Z Microfiche CD-Rom so you'll know what to change in the various spreadsheets for your model year...webdawg1Fiche 140-1 Door Panel, Glass & Hinge (From Aug 73 two Seater).xls Link to comment https://www.classiczcars.com/forums/topic/17680-restoration-spreadsheets/?&page=5#findComment-213741 Share on other sites More sharing options...
July 1, 200915 yr comment_288528 webdawg1 thanks for posting your spreadsheets. Have you done anymore you can share? I'm in the process of changing them over for use with a '73 240.Thanks again Brad Link to comment https://www.classiczcars.com/forums/topic/17680-restoration-spreadsheets/?&page=5#findComment-288528 Share on other sites More sharing options...
July 1, 200915 yr comment_288532 Have you seen the "240Z Restoration checklist"? It has the entire car catalogued with instructions on what to do with each part, and could be used a a model for your spreadsheets. http://www.jasonjarvis.com/main.htmlBTW... Today is Mr. Blakes birthday, among others. Check the homepage for all of today's birthdays. Edited July 1, 200915 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/17680-restoration-spreadsheets/?&page=5#findComment-288532 Share on other sites More sharing options...
