Posted July 27, 200520 yr comment_132204 Hey everyone. My long terms goal is to get my 76 Z a little faster, a little sweeter, and a little meaner on a moderate, part time, student budget.~ I found a set of 6-2-1 headers on a junkyard Z for $38 with a little rust, but salvagable. I'm thinking 2.25" tubing with a Dynomax turbo muffler, as it seems to have a pretty good following around here and doesn't require a separate resonator to cut down the interior noise, and the 2.25 tubing will help keep a little backpressure for midrange torque (Should I go 2.5"? please tell me why.)~ Also, I'm thinking KYB gas non-adjustables, because they cut down on the "Squatting Z" syndrome and aren't as expensive as adjustable struts, but still are pretty stiff, I think (any other recommendations? tokico blues? please persuade me, I like suggestions).~ Also, What springs would be good for autoX / mountain road driving and lower about 1.5"? I'm more interested in performance than pillowy soft ride (but I don't wanna crack my back or my frame rails, hehe). MSA springs? tokico? eibach? AZ z car? help? And finally, an LSD project which you'll hear about soon enough....Thanks fellas, I know you can handle this one, hehe. Link to comment https://www.classiczcars.com/forums/topic/16714-z-project-recommendations/ Share on other sites More sharing options...
August 2, 200519 yr comment_132802 I would go with the Tokico HP's (blue) and the Arizona Zcar springs. I had KYB's and thought they sucked, they were too week for the AZC springs. replace all the bushings in the car with some harder ones, the ABS steering couplier is great for tramsmitting the feel of the road to the steering wheel. Link to comment https://www.classiczcars.com/forums/topic/16714-z-project-recommendations/#findComment-132802 Share on other sites More sharing options...
August 2, 200519 yr comment_132805 I second that on the ABS steering coupler, my stock one was like mush and after I installed the urethane one I had waaayyyyy more road feel and IMO the steering got a little easier too. Link to comment https://www.classiczcars.com/forums/topic/16714-z-project-recommendations/#findComment-132805 Share on other sites More sharing options...
August 2, 200519 yr comment_132806 I was having a similar conversation last night. IMO, the standard (read stock) shock is the KYB. Tokicos, Konis, coil-overs, adjustables, etc. all upgrade the standard in performance and price. If you want to autocross well, buy an autocross shock and an autocross spring. If you want to drive on the street without cracking your back, buy the KYBs. I agree with Chris's take on the issue, but be prepared to feel the road.IMO, go with the 2.25" exhaust tubing. Link to comment https://www.classiczcars.com/forums/topic/16714-z-project-recommendations/#findComment-132806 Share on other sites More sharing options...
August 3, 200519 yr comment_132846 i was very happy on the street with tokico adjustables. they are a little more $$$ but worth it. they are the easiest way to tune your ride the way you like it without buying lots of suspension parts. Link to comment https://www.classiczcars.com/forums/topic/16714-z-project-recommendations/#findComment-132846 Share on other sites More sharing options...
August 3, 200519 yr comment_132858 Hello, Pennyman, I recently rebuilt the front & rear suspension on my '73. I bought a strut/spring package on e-bay that included the Tokico HP blue struts and Tokico springs. I also replaced all the bushings with Energy Suspension urethane bushings. I got the bushing set on e-bay, too. This combination has yielded a firm, yet comfortable ride. But, anything would have been an improvement over the old suspension... the struts were shot and the bump stops were missing. A couple of the original bushings were pretty well deteriorated. My teeth darn near rattled out of my jaw when I hit a bump before. Now it's a lot smoother! And no missing teeth! Link to comment https://www.classiczcars.com/forums/topic/16714-z-project-recommendations/#findComment-132858 Share on other sites More sharing options...
August 3, 200519 yr comment_132873 I liked the Tokico adjustables, too. 26th used to have urethane bushings also. Very nice stiff ride with my old 6" slots. I will probably put the adjustables back on as well as new urethane bushings. What's the lowering spring of choice, here? Arizona Z? Link to comment https://www.classiczcars.com/forums/topic/16714-z-project-recommendations/#findComment-132873 Share on other sites More sharing options...
August 3, 200519 yr comment_132909 For a street car, I always liked Suspension Techniques springs. For sway bars, Design Products Racing. For Energy Suspension, Classic Datsun Motorsports. Link to comment https://www.classiczcars.com/forums/topic/16714-z-project-recommendations/#findComment-132909 Share on other sites More sharing options...
