I LOVE THE VIDEOS!!! I know that it is alot harder than it looks...:stupid: but you guys sure make it look easy enough that I may go take some welding classes at the local community college so I can save alot of money ROFL ROFL ROFL when I redo the body on my Z. That way all I will have to do is pay someone else to paint it for meROFL ROFL ROFL ROFL
  • 1 month later...
  • 1 month later...
Update : )
Sandblasting No.2 is finished.
Here he is, the little bugger : )
Battery tray. Loving it! : )
Drivers side whatever-its-called-mount : D
Battery tray and firewall - add some compressed air and sand - ét voila!
The floors are longing for some epoxy primer : )
Before and after : )
I love Allblästring!
Tomorrow it's time for "Hugo" to say hello to some epoxy primer : )
Can you say powercoating? I had all of these "removeable parts" powdercoated. It is tough and fluids just do not harm it. We talked about epoxy paint but opted for the powdercoater. Glad I did!
I did the same project but w/o all of the rust repair (whew!). I had a rotisserie built for the Z. The painter said it was the first time he had worked on a rotisserie. He said he wanted to use a rotisserie on EVERY car he restored. I temporarily 'donated' the spinner to ZTherapy and Steve is now using it on one of his Z's.
Wait 'till you start putting it together. You will marvel at how good these spinners are when you install the suspension, brakes lines, fuel tank, etc.
When I see the shell now vs. when you first got it apart, no one knows what you have done. You saved one that should not have been saved. Well done Master!
What did you use to fill in the gaps??
http://www.henkel-lim.se/se/productDetail.php?recid=221
Art. No. 410
Varumärken (brand) PATTEX PLASTIC PADDING
IDH 360367
Contact information
consumer-ua.norden@henkel.com
Tel: 0046 (0)31 750 54 01
Fax: 0046 (0)31 750 54 02
Similar: http://forums.hybridz.org/showpost.php?p=638043&postcount=150
Despite numerous passes inside the rocker panels using a vaccuum cleaner and compressed air: There was still stuff in there. Not anymore though =)
Video should be coming pretty soon. I've been gathering material. Thanks : )
