Need HELP with rear quarter panel replacement... please!
Ahmed:
That's hard to say, you need to play with the door on the panel. Ideally, you should be able to look from the back of the car forward and not really note the rise / drop for the gas door.
But that is probably not going to be the case now, so the best thing to do is to get it to sit as uniformly all the way around as possible. If it ends up sitting high, then you can either use some sort of trim to "hide" it, or ... you tear into the panel and do it right.
Rarely is the problem that it's too low, you can just adjust that out. Granted you might have to use larger rubber bumpers, but still not a major problem.
Hope this helps.
Enrique Scanlon
The shop is located in Aurora CO off of 1-25 and 6th Avenue.
Classic Car Restoration
Great place, great prices, very quick work, and awsome owner.
PrOxLaMuS© The shop is located in Aurora CO off of 1-25 and 6th Avenue.
Thanks for the info. Have some major rust issues coming either later this year or early next year.
