Fuel pump voltage - Page 2 - Z Feeds - Classic Z Car Club Skip to content
Fuel pump voltage
On 7/2/2026 at 12:17 PM, mrfixit.joe said:
only seeing 10 volts at the pump battery is full charged.
On 7/3/2026 at 3:26 AM, mrfixit.joe said:
Car would not start during troubleshooting found if I applied 12 V to the fuel pump it would run
1 hour ago, mrfixit.joe said:
the drop happens at the relay's incoming voltage when cranking the engine. I have wired in a second relay
So, the engine won't start unless you have battery voltage directly to the fuel pump when trying to start?
Could just be a weak pump. Voltage drop when starting is normal due to the draw from the starter motor. You might find that with the relay bypass you're using that you're getting 10.5 volts instead of 10. Just enough to get the pump moving.
Where is the second relay and how do you have it wired? What are you using to control it?
You didn't say if you unplugged the AAR to see if it was drawing enough current to cause a problem. Also, it's not clear if the pump is not running or if there is some other problem. You haven't said that you don't have fuel pressure. Just that you only see 10 volts. (Edit - I think that a good pump will pump with 10 volts).
Just trying to help sort the facts. Good luck.
Edited by Zed Head
Thanks for responding again hear some more clarifying parts so I do have a fuel pressure gauge under the hood and I use it for troubleshooting after the car was restored 15 years ago. During cranking I do not see pressure so I started checking the pump only getting 9.6 V during cranking if I use a power probe and put 12 V on it, it runs the car starts and then once it switches to the run cycle, it keeps running. I installed the new relay behind the passenger seat right where the connection goes to the fuel pump. I’m using the 9 V that comes during cranking as the control on this new relay ran a fused line back to a fused junction box that I added to power some other things in the car. So all safety protocols are sterile in place during cranking the 9 V energizes the relay once the engine starts in the airflow meter takes over the control of the fuel pump the voltage is 11 811 nine and once the alternator kicks in it goes over 12 V and the pump is running fine. I am also wondering if it is a weak pump I was hoping somebody could test their voltage during cranking and tell me what they’re saying.
Another electrical component that's powered at Start is the thermotime switch and cold start valve system.
You've done some good diagnostic work. If it was mine, I'd look for possible current draws during start. Unplugging the cold start valve and the AAR are simple and easy and might show an effect. You could measure voltage drops across the connectors also but why not just unplug?
Both weak pump and low voltage could be happening at the same time.
You referred to an AAR can you explain what device you’re talking about there? I don’t recognize that term.
Looks like this. Up by the throttle body, with hoses connected to it, and an electrical connection.
Free!
VINTAGE DATSUN AND NISSAN PARTS
No image preview
X AAR Auxiliary Air Regulator Datsun 76-78 280Z S30, 79-8...
