Strange early z car electrical issue after being driven.........
Good advice, just got home from work, will go put the alternator in.
I assume I should see continuity from the alternator output wire to the positive battery cable?
Will check that before I hook up the battery and see if there is 12 volts on the "T" connector with the key on.
Ok, got it back together
Check for continuity between the alternator output post wire and positive battery cable, which it did.
Started it up, and got 14.8V at the battery........ so that's a good sign.....
I did leave the positive wires off for the following positive wire that was hooked up to the positive battery cable:
  1. Headlight Relay Upgrade
  2. Parking Lights Relay Upgrade
  3. Driving Lights
  4. Stereo
I will work and check those circuits this week.
I suspect now that either the alternator was/is flaky, or one of the wires coming off the alternator might be flaky. I will start it up with and wiggle the wires with a meter connected.
Not sure if I am happy or confused.......
Any other advice on what to check?
