Ten years ago I came across a online spreadsheet called the "2015-2020 Datsun 240Z Registry of America". Someone set it up so that owners could register the details of thier car. Why it was bracketed as 2015-2020 I have no idea. Anyway, I was the 32nd entry and it grew to about 600 entries. In 2021 I captured a PDF of the file and sometime later discovered that the online file had disappeared. The PDF is interesting to browse as it lists VIN's, orginal engine numbers, colors, owners, locations, ...etc. It has some HS30's and S30's listed at the end.
The earliest VIN is #23, owned by Chris Visscher in the Netherlands. Check it out, maybe you'll find some interesting info about your car or one owned by a buddy.
240Z Master Registry.pdf
2 hours ago, Namerow said:
The entries aren't in order by VIN. To search for a specific VIN, hit 'Control', then 'f', then enter the full six-digit VIN that you're looking for.
Actually, the report is in VIN sequence, column #2. The six-digits in column #1 are the registry numbers.
