Hi John,
I used vise grips and heated the manifold with a propane torch. It makes marks, but I polished most of that out and re-plated the part. If I had to do it again, I would try to find some sheet metal that was the thickness of the slot. Maybe cut a 8 inch by 2 inch strip and slide the long edge in the slot. Use heat and, grab the plate like handles.
