As the topic says, I'm looking to purchase just the MSA Premium exhaust headpipe. It adapts the stock exhaust manifold flange to the 3 bolt flange used in the MSA exhaust kits.
It will let me create a custom exhaust with the flange, that should be compatible with the MSA 6-1 headers down the road.
Also I would be interested in the mating flange for for it as well, but I imagine this is often already going to be welded to another pipe.
Thanks all
Dave
Edited by DaveR
Yea that might work. I'll keep it in mind.
I was considering the MSA one specifically because it already had the flange on it and if I ultimately got headers from MSA maybe the shape and position of the OEM Exh. Manif. + the MSA headpipe would occupy the same space as the new MSA header and might slot right in.
May I ask what muffler you have on that car with the stacked pipes?
Edit: Nvm I found all the info here:
Thanks
Edited by DaveR
