I am trying to resurrect a 75 280Z that has been sitting for several years. Traced wiring, replaced coil, tested wiring, following Chilton manual. It will run on carb cleaner. With a hot wire connected to the fuel pump I have fuel to the injectors. I tried a noid light and found no injector trip. Computer bad?
first off: Download the Factory service Manual. The Chilton's Manual had very limited info on the EFI system. Quick guess: try to track down the fuel cutoff for youre 75 I think it is different then my 77 (located in the AFM).
