Sealant inside valve cover? - Open Chit Chat - Classic Z Car Club Skip to content
Does anyone know what kind of sealant was used inside the valve covers?
Or can somebody answer me this... is the sealant necessary?
It is my understanding it is like a sealing wax, needs to be heated well above engine temp to become plyable or melt. It is what holds the baffle & PCV tube in place.
Bonzi Lon
Never used any, just a good gasket, properly tightened, should be enough to keep any oil from leaking.
Oops! Misread post, thought it was about the valve cover gasket.
Edited by duffman
Oh ok, the reason I ask is I have a "nissan" japanese valve cover and it has not been used in a while so the steel on the inside has surface rust... I assume I have to remove it to clean it up, but I wanted to know how to seal it once I get around to it? I can post pictures if necessary as well.
