i'm in the planning stage of a major project. i'm planing on putting together a tube framed, vg30et powered 240, using suspension components from a z31. The reason for using a v6 in this project is to put more weight on the rear wheels, & even out the weight distribution, but i dont know a great deal about these motors. which leads me to my questions:
1. How much boost can the stock turbocharger produce?
2. Are these motors difficult to extract power from?
thanks in advance for the help
https://www.classiczcars.com/forums/topic/3786-vg30et-power-gains/
I wouldn't run the stock turbo above 10psi. Get a T4 compressor & back-cut the turbine if you want more flow. 4-500HP is very doable, contact Jim-Wolf (California) or Malvern Racing (Virginia)for some workshop info.
Let me clarify what I meant with the'10psi' comment...
The ceramic-turbine T3 should be able to run at ~15psi all day with no problems. But my point is that the efficiency of the turbo would be quite poor at this pressure ratio. A larger compressor & turbine modifications should see the discharge temperature & rpms lower for the same flow rate/pressure ratio.
I have seen many examples of a better turbo producing more power at a lower pressure ratio. Especially when we are talking about stock units working real hard to maintain the boost desired.
