I am about to enter spindle pin hell so before I start am going to build a puller.
Does anyone know the thread size and pitch of the pin itself so I can tap the puller? I've gotten all the other specs I need but this one.
Best,
H Houghton
https://www.classiczcars.com/forums/topic/34052-spindle-pin-hell/
Thank you,exactly what I needed. Being of the school of thought that thinks it can sense money in my wallet if I put it on the console, I want to get everthing ready before I start so it won't know I'm sneaking up on it til its to late to resist.
Use a nissan lugnut, then weld onto the sae allthread. If you have a thrust bearing from the front suspension, use that between the pipe and pulling nut. It will keep the friction down.
http://i30.photobucket.com/albums/c301/dlh2460/spindle%20pin%20tool/spindlepintool002.jpg
The things you won't need in this pic is the big 3/8" thick spacer I made, and the bronze flange bushing.
the one I used isn't from the suspension, I bought those and they fit perfect. but the hole in the thrust bearing from the suspension is more than big enough, you will probably have to get a bigger washer.
cool,I'll go parts fishing tomorrow.
Easiest way I have found to make the puller is with a 12" piece of 1" all-thread and a 10" piece of 1" black or galvanized pipe. Drill and tap the end of the 1" all-thread for the 12 X 1.25mm thread. A couple hardeded washers and grease and you will be good-to-go. Don't forget to get a 1" nut for the all-thread.
