I was asked the other day if I had ever seen an L6 valve cover for a 3.0 liter and I said no. After some research I found there was a skyline motor (I6) of this type made in Australia.
Does anyone have a picture of the valve cover?
Will it fit an L6?
http://en.wikipedia.org/wiki/Nissan_Skyline
GTS-R
The ultimate version of the R31 was the RB20DET-R powered HR31 GTS-R Coupe (800 units built for group A evolution). It had a reworked version of the normal RB20DET with a much larger turbocharger on a tubular steel exhaust manifold, as well as a much larger front mounted intercooler boosting power to a factory claimed 210 ps (154 kW), with racing versions making 460 hp (343 kW) in Group A trim.
Calsonic Nissan Skyline GTS-R R31
Models: 'Japan'
* 1800I - 1.8 L CA18(i) SOHC I4, 100 hp (75 kW)
* Passage GT-D - 2.8 L Diesel RD28 SOHC I6, 92 hp (68 kW, 173 N m)
* Passage GT - 2.0 L RB20DE DOHC I6, 155 hp (114 kW)
* Passage GT Turbo - 2.0 L RB20DET DOHC turbo I6, 180 hp (133 kW, 225 N m)
* GTS - 2.0 L RB20DE DOHC I6, 155 hp (114 kW)
* GTS Turbo - 2.0 L RB20DET DOHC I6, 180 hp (133 kW, 225 N m)
* GTS-X - 2.0 L RB20DET DOHC turbo I6, 190 hp (141 kW, 240 N m)
* GTS-R - 2.0 L RB20DET-R DOHC turbo I6, 210 hp (154 kW, 245 N m)
* GTS Autech - 2.0 L RB20DET-R DOHC turbo I6, 210 hp (154 kW, 245 N m)
'Australia'
* Pintara - 2.0 L CA20E I4, 102 hp (78 kW, 160 N m)
* GX, Executive, GXE, Silhouette, Ti - 3.0 L RB30E SOHC I6, 155 hp (114 kW, 247 N m)
* GTS1 - 3.0 L RB30E SOHC I6, 176 hp (130 kW, 255 N m)
* GTS2 - 3.0 L RB30E SOHC I6, 190 hp (140 kW, 270 N m)
'South Africa'
* 2.0GL, 2.0GLE - 2.0 L CA20S I4, 106 hp (78 kW, 163 N m)
* 2.0SGLi - 2.0 L RB20E SOHC I6, 115 hp (85 kW, 174 N m)
* 3.0SGLi - 3.0 L RB30E SOHC I6, 171 hp (126 kW, 260 N m)
Have you ever heard of an L6 valve cover that has 3liter markings?
No, not factory from Nissan. If there was such a beast, it would have to be a custom or aftermarket job.
That looks like a modified Kameari Valve cover.
It's one of the few different Kakimoto Racing/Kameari valve covers that were sold. Some of the others are in that thread but it's not modified.
Edited by sblake01
