Posted July 1, 200817 yr comment_252574 does anyone have it? just the ones that connect under the passenger footwell that run into the engine bay Link to comment https://www.classiczcars.com/forums/topic/28615-pinout-diagram-for-engine-harness/ Share on other sites More sharing options...
July 2, 200817 yr comment_252581 It is possible that someone may have the information you are looking for. It would be to your advantage to state the year of the car for which you need a wiring diagram. Link to comment https://www.classiczcars.com/forums/topic/28615-pinout-diagram-for-engine-harness/#findComment-252581 Share on other sites More sharing options...
July 2, 200817 yr Author comment_252582 ha, right. 77 280z Link to comment https://www.classiczcars.com/forums/topic/28615-pinout-diagram-for-engine-harness/#findComment-252582 Share on other sites More sharing options...
July 2, 200817 yr comment_252585 May be this is what you are looking for.Pages from 88-93.pdf Link to comment https://www.classiczcars.com/forums/topic/28615-pinout-diagram-for-engine-harness/#findComment-252585 Share on other sites More sharing options...
July 4, 200817 yr Author comment_252736 what manual is this from? Link to comment https://www.classiczcars.com/forums/topic/28615-pinout-diagram-for-engine-harness/#findComment-252736 Share on other sites More sharing options...
July 31, 200816 yr comment_254949 what manual is this from?It appears to be from the 77 280Z FSM. If you don't have one you can download one here. Link to comment https://www.classiczcars.com/forums/topic/28615-pinout-diagram-for-engine-harness/#findComment-254949 Share on other sites More sharing options...
July 31, 200816 yr comment_254977 77 Fsm Link to comment https://www.classiczcars.com/forums/topic/28615-pinout-diagram-for-engine-harness/#findComment-254977 Share on other sites More sharing options...
July 31, 200816 yr comment_254998 77 FsmThat link (the word 'here.' in post #6) will take him right to the 77 280Z FSM. Link to comment https://www.classiczcars.com/forums/topic/28615-pinout-diagram-for-engine-harness/#findComment-254998 Share on other sites More sharing options...
August 1, 200816 yr Author comment_255123 thank you Link to comment https://www.classiczcars.com/forums/topic/28615-pinout-diagram-for-engine-harness/#findComment-255123 Share on other sites More sharing options...
