Posted
Turn 10 at Texas World Speedway is a 180 degree right-hander with about a 100 foot radius. Speed through this turn is approximately 35 mph and the g-forces are to the left.
My Mikuni fuel pick-ups are on the engine side of the carb. Yep, the centrifugal force of the lengthy, relatively hi-G turn sloshes all the fuel away from the ports.
Question: Does anyone know where I can find information on constructing baffles to minimize this fuel starvation problem? I've used the search function but not found any key-word matches.:cry:
Thanks in advance.
Frank
It's not starvation that is the problem, it is flooding. On right handers the fuel sloshes out the float bowl vents and goes into the engine. A really good float level adjustment will minimize the issue as much as possible, but Tom Holt posted a much better fix a couple years back in this thread:
http://www.classiczcars.com/forums/showthread.php?t=18948
