Posted July 7, 200619 yr comment_173721 I finally got the Z running without stalling!!! Now comes the bad news... The back carb is leaking out of some tube pointed towards the air cleaner. WTF could cause this? Link to comment https://www.classiczcars.com/forums/topic/20698-more-with-the-flat-tops/ Share on other sites More sharing options...
July 7, 200619 yr comment_173723 it's not the tube that links front carb to rear is it? Link to comment https://www.classiczcars.com/forums/topic/20698-more-with-the-flat-tops/#findComment-173723 Share on other sites More sharing options...
July 7, 200619 yr comment_173724 I don't know much about flat-tops, but I'm wondering if the float level is too high, or the float is stuck, sending fuel out of the float bowl vent hose? (Do flat-tops even have float bowl vents?) Link to comment https://www.classiczcars.com/forums/topic/20698-more-with-the-flat-tops/#findComment-173724 Share on other sites More sharing options...
July 7, 200619 yr comment_173725 Check the window on the side to see if the fuel level is correct. There is a line on the window showing correct height. If it's over then your most likely overflowing. They do breathe a bit, but it seems yours is breathing to much! Link to comment https://www.classiczcars.com/forums/topic/20698-more-with-the-flat-tops/#findComment-173725 Share on other sites More sharing options...
July 7, 200619 yr Author comment_173726 That's what I was thinking so I'm gonna take off the back one again and see Link to comment https://www.classiczcars.com/forums/topic/20698-more-with-the-flat-tops/#findComment-173726 Share on other sites More sharing options...
