Ron, that mesh isn't even showing any signs of wear. Honestly, you'll likely be pleased with almost any tightly woven metal screen. Just be certain that you can see through it well. And you are right, I've put the cabinet through the paces.
I can't afford the upper end equipment of this nature new, so I have found used units for both my cabinet and compressor. 4K for the equipment new.... $700. used.... Just be patient and picky and you can do the same thing.
Ron,
We'll know soon- when the boys go down for their nap I'll get on it today!
The mesh I have is much tighter than window screen, I'll see how its opening are relative to the glass bead-I am suret they are fine for 80 grit material.
Will
