I don't think KN offers this type of filter.
I was thinking about getting 2 longflo replacement elements $5 each and zip tie 1 on each horn.
I could have sworn I seen a race car with a setup that looked like this.
Would this work?
If you call them, you will know!
I have had them get involved with a project simply bacuse the thought it was interesting(and they thought it would be marketable).
Will
P.S. probably!
Before I call could someone first explain what exactly is a sock filter so I don't sound like an idiot.
I figured it was just a foam type filter that fit's over the horn. I didn't think KN made foam type filters. I willl call them.
I was thinking also this could work if I took the filter out of it's housing and zip tied it to the horn. http://cgi.ebay.com/ebaymotors/HKS-3-BLUE-HIGH-PERFORMANCE-FOAM-AIR-FILTER-F1-TUNNEL_W0QQitemZ7996250625QQcategoryZ33659QQrdZ1QQcmdZViewItem
The sock can be made from their media as well(they use cotton gauze(cheese cloth) over a formed screen). It would need a wire(screen) frame to support it inside(keep it open and from being sucked into the carb), and a hose clamp/tiewrap to secure it to the ouside of the horn to keep all of the intake air flowing through, and not around, the filter.
Will
P.S. you are on the right track, but foam is quite restrictive
red-sox-pr.gif Picture of a Filter sox I found online.
I think I'm going to order 2 ram stacks and then try to make something like this.
Some aluminum sheet metal and see if my old man can TIG something up. Slap a 3" universal KN on the end and I think this will be badass.
Going to be awhile have a 73 and just bought some SUs so still need to figure out how to rig this up.
