Posted June 22, 200421 yr comment_86076 Hey guys,As is the usual story the clock in my 260 doesnt work, i have a friend who has offered to give me the internal motor from his late model 260 (as i have the 240 gauges in mine....early 260 yes).Is it possible to remove the face from the clock without breaking anything? Or am i just gonna have to put the late model clock in that doesnt match....Thanks Link to comment https://www.classiczcars.com/forums/topic/12300-clock-problems/ Share on other sites More sharing options...
June 22, 200421 yr comment_86101 Swapping clock innards is a simple task. There are a couple of screws holding the face plate and bezel to the canister, then you remove the clock handles to remove the back face plate. The next step involves removing the hold down nuts on the back of the canister, pushing the wiring grommet into the canister and feeding the wires through.Should take you no more than 15 minutes AFTER it's out of the car. Now getting it out of the car..... That's another story.Enrique Link to comment https://www.classiczcars.com/forums/topic/12300-clock-problems/#findComment-86101 Share on other sites More sharing options...
June 22, 200421 yr Author comment_86103 Thanks alot, thats all the conformation i needed, i wasnt sure if the hands would come off, do they come straight off the spine? or does that unscrew? Link to comment https://www.classiczcars.com/forums/topic/12300-clock-problems/#findComment-86103 Share on other sites More sharing options...
June 23, 200421 yr comment_86115 Or you can just buy a reliable clock from Auto Meter if you have money to burn. Why not go for the whole range, they fit perfectly. Cheers Link to comment https://www.classiczcars.com/forums/topic/12300-clock-problems/#findComment-86115 Share on other sites More sharing options...
June 23, 200421 yr Author comment_86119 I prefer tha classic gauges....isnt it always the way, purest in one sence and an huge intent to modify in another. Link to comment https://www.classiczcars.com/forums/topic/12300-clock-problems/#findComment-86119 Share on other sites More sharing options...
June 23, 200421 yr comment_86125 The clock hands will pull straight off the shaft.As a suggestion, turn the clock's hands to 12:00 before you remove them. I don't know that it makes a difference after you put the hands back on and don't have them aligned, but why take the chance?Enrique Link to comment https://www.classiczcars.com/forums/topic/12300-clock-problems/#findComment-86125 Share on other sites More sharing options...
July 4, 200421 yr comment_87414 http://zclocks.com/Very pleased with the service.In fact the Fairlady Z clock pictured on the page below is mine. The before and after photographs are accurate.http://zclocks.com/expertise.htm Link to comment https://www.classiczcars.com/forums/topic/12300-clock-problems/#findComment-87414 Share on other sites More sharing options...
