Skip to content
What other seat fit a 73 240Z
I just bought my first car (car is ten years older than I am) and it will need new seat soon. I was thinking that I could just head over to the junkyard. So what will fit? Thanks...
Hi, Robert, and welcome to the group! I think I've seen an answer to this question on the e-mail list, so let me do some checking and I'll post back here.
gary
Gary P
'72 240z - 5 spd., Crane Cams elec. ignition mod, BFG Comp TAs (needs tlc)
'97 JGC Laredo - K&N filter mod, Don-A-Vee TB spacer, factory skids/front tow hooks, Con-Ferr roof rack
OK, Robert, I found what I was searching for. I'll cut and paste the relevant parts of several posts to the e-mail list from the past year, for future reference here. It looks like Rob probably has the best suggestions, but I'll also include some comments from Kyle & Manny, as well.
gary
Date: Tue, 25 Jul 2000 09:00:53 -0400
Subject: Re: <240z-club> eagle talon seats
Ernie:
If you are considering a seat swap, please check out the seats from either
a CRX or Civic SI. I got seats from an '88, but other close years will
work. The Civic versions have better fabric, otherwise the same. They are
as low and as light as stock Z seats, have excellent side bolsters and
under-thigh support and are generally cheap. THey look terrific, and the
velour is cool in the summer and cozy in the winter. All you need to
install them is a flat piece of metal for the rear to make a bridge across
the stock Z floor supports because the stock Honda tracks are just a bit
wider than a Zs. You'll also need a Dremel or other cutting tool to remove
the stock Honda bolt loops in the front and to cut a bolt clearance notch
in the outside rear supports. I swapped my seats left/right so that the
recline adjusting knob didn't press against the seatbelt at full rearward
position. Except for the Dremel tool, all you'll need is an electric drill
to make new mounting holes.
BTW, I carefully measured and considered every bucket seat in five
different junkyards before coming to the conclusion that the Honda seats
were THE seat to use in a Z.
WARNING: Some years Honda put the outside track flat on the floor and the
inside track higher - on the side of the "driveshaft" hump. You do not want
these seats, despite the fact that the rest of the seat is identical to
what I've described. You want seats with both tracks flat on the floor. I
paid $125 for two in excellent condition. YMMV.
and a couple more comments from Rob:
Date: Fri, 5 Jan 2001 14:24:45 -0500
Subject: Re: <240z-club> performance upgrade
<snip>
My last suggestion for low buck improvement is to toss the stock
seats and get some from a late 80s Honda CRX SI or Civic SI. These
seats are light, easy to install, easy to find, cheap to buy, don't
raise your head height and feel really, really great! They have
support under the thighs, in the small of the back, and at the side
bolsters that makes the driving experience soooo much better. You'll
feel like a runner who got out of loose leather wingtips and into
new, snug Air Jordans. Autocrossers will tell you that for the
quickest time, the driver's body has to be immobilized -- impossible
on slick, flattened, unsupportive, 27-year-old stock seats!
Here's Kyle's comments regarding Talon seats:
Date: Mon, 24 Jul 2000 15:43:02 -0700
from ernie ruiz
> Has anybody put the Eagle Talon seats in their Z?
Yeup!
> If so what year did they come from and will eclipse
> seats work?
I got 91's, AFAIK... Laser/Eclipse/Talon is all the same.
BUT - they're a MAJOR PITA to install. If you're over 5'3",
you'll have to *completely* remove the stock seat brackets,
fore and aft, and bolt the seats directly to the floor.
Too bad, too. They'll line up with the stock mounting
provisions, but the seats are so tall, your head will be
thru the roof. :-(
If I had a time machine, I'd wind it back and NOT do it.
I'd get the stock seats refurbished.
<snip>
And finally, here's what Manny had to say:
Date: Wed, 20 Sep 2000 15:48:10 GMT
Subject: <240z-club> <L6> Starion Leather Seats...
- -- Group Message from "Manuel C"
Good Morning,
After installing my new wheels...I decided to go back to my stock seats. I have a pair of Starion Leather seats that are available to a good cause (any proud z owner). They have adjustable head-rests, with Lumbar and side
bolster dials.
The Passenger side is in Vgood shape, the Driver side needs some work. I used adapter plates and only made two holes (front rail) for the install.
I would not recommend them for anyone taller than 5.10, you will loose some
adjust-ability sliding back.
<snip>
[This message has been edited by norcal z (edited 02-19-2001).]
Thank you very much. I hate my current seats but I love my car sooooooooooooo much. Now all I have to worry about is a carb.......
  • 8 years later...
Mazda Miata seats work GREAT in a Z. I bought a set of used seats from a kid that upgraded his Miata to leather. The seats bolted into my '72 with just a little bit of modification (if I remember, I only had to drill a couple holes in the mounting area for the seats on each side of my Z). I used standard washers as spacers to raise the seats a little and also to adjust them to get the correct tilt.
Best wishes,
John
It isn't the best picture:
http://www.classiczcars.com/photopost/showphoto.php?photo=29801&ppuser=6558
and I'd like to get them recovered some day but I do like the way they look in the Z. Similar outline to the stock seats.
