Hello,
I have searched through this site as well as a couple more and cannot find out if anyone has actually installed a 2 sp fan from a 3.8 ltr Taurus into an early Z with a L6 motor. I picked one up at a local yard and this thing is huge. I think that it is way to deep. Any thoughts out there. This is for my early 260Z. Thanks, Skip.
https://www.classiczcars.com/forums/topic/10741-taurus-fan/
Dude,
try the HybridZ .org forum, they got the taurus fan all worked out. Only thing is I think you gotta make sure you got the AMPS to power the thing.
While you're at it, install an LTD fan into the heater system...
Try this first:
http://www.fordmuscle.com/archives/2003/02/electricfan/index.shtml
:D
https://www.classiczcars.com/forums/topic/10741-taurus-fan/#findComment-72713
Though it would be a little more costly, there is a man on ebay selling good quality fans that pull 1800 cfm, more then enough for your Z. Cost 35-45 dollars.
Get yourself a thermo-switch to control the fan, and your good to go.
Cost 17-40 dollars.
https://www.classiczcars.com/forums/topic/10741-taurus-fan/#findComment-72723
