My 260Z HVAC control panel - Interior - Classic Z Car Club Skip to content
So after doing some extensive rewiring in Goldies front end and fuse panel I found my A/C compressor wasn't kicking on. In the search, I noticed a problem with the selector that prompted me to remove the HVAC control panel and below is the mung I found attached. I guess it hasn't been cleaned - ever. So I did. I used Meguiars Hyper Dressing as my cleaning solution and it worked well.
I'd done one of these several years ago. I don't think it was quite this filthy. Everything cleaned up well and it all works as it should and it solved the issue with the A/C microswitch.
