Floor temp light (76 CA model) - Electrical - Classic Z Car Club Skip to content
Hi guys,
My original fuel sender was leaking around the positive contact. I replaced it with a 2 pole sender from ZCD. Since I lost the 3rd contact for the thermistor (low fuel), I only used 2 wires (pos and ground). The fuel gauge is working (I do need to bend the float's arm - I have 12 gallons there, it is showing barely half full).
Now my floor temp light is always on (cranking/driving). My model is CA, I still have the sensor/catalytic converter installed. The sensor used to work. I checked the electrical diagrams - the dash lights for Floor/Fuel Warning are sharing the same wire.
I am not sure why the fuel sender's wire would affect the Floor temp sensor's bulb? The only thing I haven't checked is the floor sensor's relay under the passenger seat. I probably can ground the sensor's connector in the back to see if the light goes out - this should verify the relay's operation. Any other ideas?
Thanks!
Den
Edited by darom
Correlation does not imply causation. What you leave out, though, is how you adapted the harness to go from the Yazaki round terminal plug to the individual wires. What did you do with the yellow/blue wire?
I am a big fan of Deutsch connectors. I put a 3-wire one to replace the Datsun's one. The yellow wire goes to the positive on the sender's unit, the black - to the sender's ground. The yellow with blue stripe is not being used.
So test.
  1. Make it where you can access the yellow/blue wire.
  2. Put the key in ON.
  3. Verify the floor temp light is on.
  4. Ground the yellow/blue wire.
  5. Verify the fuel light comes on.
  6. See if the floor temp light turns off.
Will do. Thanks. Still not sure how the yellow/blue wire for the fuel sender's thermistor affected my floor temp light. I checked one of the floor temp sensor's wires for the ground connectivity and there is one.
Edited by darom
I don't think it did. However, test and eliminate.
I did the yellow/blue wire grounding test. I had both the Floor Temp and Fuel warning lights on. I guess I have an independent to the fuel sender's thermistor issue with the Floor Temp sensor. I will check the relay under the pass seat.
