As I’ve documented on this forum before I got kind of stift by the auction company and the previous owner of my 77 280z. The frame rails are rusted and need replacement to pass inspection and something is wrong with the rear suspension. I’m trying to not spend too much money at the moment but still want good parts that will stay on the car trough out the build as doing thing twice costs more in the long run.
I will have to take the car to a body shop to get the frame rails welded so I’ll be looking to get pre made frame rails to save on labor cost. That gives me two choices, 1,5mm thick reproduction rails from KF vintage or the 3mm thick rails from Apex. The KF rails are send trough a warehouse in Spain so that saves a lot on import cost for me but the Apex rails are twice as thick which may give the almost 50 year old car some much needed strength and rigidity. Does anybody have the Apex rails on there car and how are they holding up?
As for the rear suspension the question is if it is the chassis itself that’s crooked or something in the suspension. As I can’t find many stories of bend chassis online I’ll take the bet that it’s the rear suspension. That means I’ll have to look for adjustable rear control arms. That way even if the chassis itself is a little bit crooked I can tune it out for now till the car will be fully restored. Again that search let me back to Apex, there was also Silver Project from Europe which was a lot cheaper but I don’t hear much good from them. Has anybody installed the rear (or front) control arms from Apex with mostly stock suspension?
I currently have a list of products form Apex which interests me and I’ll probably wait till Black Friday to see if they got any good deals. I don’t know if I’ll order everything but the frame rails and rear control arms I’ll probably order. This is what I’m interested in at the moment:
- Frame rails
- Rear control arms
- Fender brace (If the car gets welded anyway, why not)
- Rear strut brace
- Front control arms
- Low profile outer tie rods (I run 15” atm)
- Inner tie rods (because of the threat difference)
- Steering knuckles
All combined should give the chassis and suspension a nice upgrade and the adjustability I need to get the car on the road. I do plan on keeping the four lug setup and the coilovers that are currently on the car. I do like there coilovers but That may be too much money for now. Yesterday I contacted Apex Engineered with some questions and they claim that the suspension components I’m looking at do work with the stock components.
Are there people on here running Apex components (except the track attack kits) and what is your opinion on them.
*note: this is a copy of my threat on HybrideZ
Making the frame rails alot thicker changes the handling characteristics of the chassis. It also moves the potential failure points. Unless you plan on running tremendous power I wouldn't expect thicker frame rails to be necessary
I put Apex front and rear control arms on my car this year, along with BC coilovers, and am loving the setup. Their control arms are very well built and provide a lot of adjustment (more than I need for a fun backroads car). If you do get the rears, I'd skip on the dust boots. It was impossible to tighten up the hardware without destroying the boots.
Bushings.
  • 3 weeks later...
After many nights thinking about it, the current Black Friday sale and optimizing my order for the most value for my money I finally decided to pull the trigger. Maybe it’s because of the size and weight of the total order but the calculation of the shipping was a bit weird. As the parts will need to be shipped to the Netherlands I knew the shipping would be expensive but my shipping came down to almost $600!! By combining some stuff I got the shipping to drop down to $280,- while still giving me the stuff I wanted and basically a free rear strut brace. Here is a list of all the stuff I got:
- Front fender brace
- Frame rails
- Rear strut brace
- Steering knuckles
- Front crossmember
- Upper steering rack clamps
- Rear control arms
While weighting my options Apex dropped there Retro Mod line of suspension which allows you to keep the stock R180 or R200 long nose differential, axles and spindles. I really wanted to get the new rear suspension and subframe but found it to be too expensive for me at this time. By dropping the rear subframe I got to order the front crossmember, control arms and steering knuckle and still be a lot cheaper off. Weirdly ordering all the front suspension bits separately was almost $300,- cheaper than buying the Retro Mod front suspension kit. Seeing as I don’t need the tie rods (and the steering rack, you need to buy that separately) I’m even cheaper off.
I already contacted my body shop about it and I think we will have the car back on the road by the end of winter. They will also put the car on a frame machine and measure the car to see if the chassis is twisted. And yes Zed Head I heard you about the bushings but besides that there might be more going on. Along with the new control arms all bushings will be replaced before going to the body shop.
