19 minutes ago, HS30-H said:
Nissan's L24 engines were put together in the same place as the S30 L20A engines, the aforementioned main Yokohama plant. They have a Nissan Engine Museum in one of the original 1930s buildings still standing, adjacent to the main plant in Takara Cho. Recommended for a visit.
The point being you are asking for photos of the "240Z assembly line" but showing a photo a photo of a quite different location. Many of the component parts and sub-assemblies of 'our' cars were made in plants elsewhere, then put together at Nissan Shatai Koki's facility in Hiratsuka.
Like most car companies parts are made in different locations and shipped in for final assembly, in the case of the S30 model this was Nissan Shatai. From what you have said the engines were built in Yokohama, were the gearbox and other mechanicals done there as well. What parts were made at Shatai, the main body pressings? What were the other major sub assemblies and where did they come from? Do you have any photos of the Shatai assembly line and factory? What I have posted so far in this thread are from what was previously posted on these forums.
Is there a document that details the procedure for the build. We know from looking at our cars that the bodies were welded together, then the sound deadening applied, gray primered, chip seal of the underside and then front wings, doors and cowling along with bonnet and hatch fitted before final paint. Interior and glass along with electrics fitted before the mechanical parts were then added on the assembly line. Is this the correct sequence?
1 hour ago, HS30-H said:
None that I'd break a promise and post here.
And therein lies the problem and why history ends up getting lost. In the larger scheme of things it probably doesn't matter how our cars are built and the details will be lost to time. Time to close this thread.
But why do you expect to see detailed photos of a commercial, industrial process over and above the few PR photos that Nissan chose to show us?
They gave us plenty of information about the product itself and a fair bit of information about the company and its various operations. As far as Nissan are concerned, anything more than that is really none of our business.
