If the hole is just next to the rear wheel well in front of where the "wall" goes up to the rear deck floor I think it's just a rubber plug. I believe the indent just below right of your finger is where a seat belt retractor would go.
https://www.classiczcars.com/forums/topic/69568-hole-help/#findComment-679485
It is just a hole, normally has a rubber plug in it. I have used it to mount seat belt retractors with proper re-enforcement underneath where it exits through a frame box member.
https://www.classiczcars.com/forums/topic/69568-hole-help/#findComment-679491
