Hello All,
I am swapping to a 250z(N36) fan 240z(E46) balance tube. I'm trying to figure out which throttle linkage it requires. Do I need a full 240z throttle linkage from balance tube to fire wall or would replacing the shorter "J Rod" from the shorter 260z to the longer 240z be the only thing i need.
Thank you
https://www.classiczcars.com/forums/topic/69364-240z-balance-tube-swap/
