June 8, 20187 yr Author comment_550634 It doesn't make sense, but since the engine was operating (smoothly) I drove around the block to test it a little, then put the cover back onto the ECU, taped up the un-used ring terminals from the distributor junction block, and the rev counter started working. It still needs a proper tuner some adjustments, but I put about 12 miles on it today. Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=3#findComment-550634 Share on other sites More sharing options...
June 8, 20187 yr Author comment_550635 I still plan to put on a kill switch for the new module. Would you prefer to break te switched 12V line, or the connection from the + pole on the coil to the B terminal on the module? I think the first location would be preferred, as that is what occurs when you turn onn the keyswitch. I have a remote 10A relay that would be ideal for that. Link to comment https://www.classiczcars.com/forums/topic/59949-engine-temperature-sensor-woes/?&page=3#findComment-550635 Share on other sites More sharing options...
