Skip to content
WTB 72 lower center grill support
I know this support is spot welded on, if you have one in good condition that has the spot welds drilled out. I need one.
Thank you
I should clarify the part I am looking for is welded onto the lower radiator support cross member and the bottom bracket of the grill bolts to this part.
