Skip to content
Tuning this 3.0 on SUs...
Factory Tachs can be notoriously inaccurate.. but they do have an adjustment on the back. I would confirm RPM's with a second digital Tach. If they match then you may want to consider adjusting your dash tach.
What ignition are you currently running?
Factory ignition, MSD Blaster 2 coil / ballast, Pertronix Ignitor points replacement.
