Over the last few weeks, i did some small things and collected a lot of stuff again. First, I exchanged my US-spec front lower valance. Before:
And After: Euro spec valance:
In case you're wondering, what's the difference? The euro spec has the additional mounting holes / nuts to install the Euro spec front spoiler lip. Here you can see the two side-by-side:
This allowed me to temporary test fit my wobbly, worn-out, cheaply-repaired Euro spec front spoiler lip:
I still need to change the corner valances to euro spec ones, but also the lip needs a replacement, as this one is beyond repair. But at least I could see how it will look:
People often say they're impressed with what I'm able to find for purchase. But this time I even surprised myself. You might remember the Eaglemoss Fairlady Z Kit that I bought a while ago and came with a bunch of magazines? The set has dedicated folders / binders to put the magazines into. I always had two missing, so some of the magazines were stored "loosely". Luckily, I was able to find two unused Folders for exactly that kit in Japan:
So all the magazines are now nicely stored:
And my book shelve / archive looks much better :-)
I also bought a small lot of vintage Datsun (Switzerland) Stickers. Some of which I haven't got yet in my collection:
Then I also got a bunch of Documents:
First, the Datsun Sports 311 Introduction Bulletin from 1967.
Theoretically, it has nothing to do with my 240Z project. But with this car the FS5C71A transmission was introduced
The original Overdrive transmission, used in a similar (albeit slightly different) configuration in the early EU-spec 240Z. To find information about it is a bit tricky. So when I saw that this booklet has more details about it, which I haven't seen before. I had to get it:
Speaking of transmissions, I also got the Japanese Nissan Transmission service manual from 1974:
This one includes the later FS5C71B transmission and some general information about Nissan transmissions, which is not found in the 240Z specific documentation:
And then i also got another issue of the "Nissan Star", Swiss customer magazine from 1990, which always has cool insights into Nissan from those days: 20250620_181329-Kopie.jpg
More to come soon.
  • 4 weeks later...
I have some urgent projects around the house which I hope to be able to finish in the following days, but I hope after that I have loads of time for the Z again.
So this will be a very quick update: I got some nice documents from Japan again:
The first one is the "Z-2" Service Shuho Book, which is the equivalent of the English bulletins. They have become quite pricey recently, so i stick to focus on the most important ones, but when Z-2 (introduction of the Automatic transmission cars) showed up for a reasonable price, i made sure to get it. Here's my collection so far. There are plenty more, which I hope to add to my collection whenever they pop up for a good price.
The second document is the December 1973 Nissan sports option catalogue for the HS30 "240Z". It's probably the most extensive one, which is 12-pages strong.
It focuses on the HS30 Fairladies only, which means most of the listed parts also fit my HLS30 car. The other catalogues are either much thinner, or focus on a different car (Z432, for e.g.) or a whole range of Cars (240 / 260 / 280Z). But basically, it was a good price and missing in my collection, so that's why I got it. I hope for more updates, soon, I have some things planned... And I have some very cool things waiting to be picked up by me, or on the way here...
  • 3 weeks later...
It has been a serious while since I was able to put some actual work in the car. I had some urgent projects on the house to complete, and then I managed to injure my hands, but now I'm back at it again.
First, I had to re-install my tank. Since I sold my new fuel tank including rubbers and straps at the Japanclassic, to help somebody get is car running again quickly, I had to wait for a new one to arrive from S30.world.
Unfortunately, new straps are currently not available anymore, so i had to go through my set of existing straps to get the best ones for temporary usage:
First i had the rubber insulator blocks installed on the tank:
And then had it all wrapped to avoid scratches on my brand new tank:
And then everything installed. Thanks to my new transmission hoist, this was a lot easier than last time.
And last but not least, i had the drain plug installed, which comes with the tank:
Next? Front end work. Ever since I had my wobbly bent EU spec front spoiler installed, I was wondering myself which route to go. EU-spec corner valances with the mounting holes for the spoiler, but no holes for the Lower turn signals or other way? After thinking about it for a while, i decided to take the best of both worlds. Some might call it sacrilegious, but I decided to go what appeals the most to my eyes. US spec lower turn signals, but EU-spec front spoiler (which also helps stabilize the car and is not just for the looks).
My original thinking was that the US-spec corner valances need to be modified with that "loose-nut" mounting brackets for the lip, but when checking my EU-spec valances, i realized that on the corner valances (unlike the center valance) there is only a simple hole.
So the modification of US-spec valances to fit the EU-spec spoiler is simply to drill a 5mm hole in the right place. To get the right place, i made a nice little template from tape.
Transferred it from the EU- to the US-valances, and drilled / cleaned it.
Unfortunately, I found that on the LH-side somebody had previously drilled holes in the wrong places, for whatever reason. Probably they had some different spoiler installed? I'll leave that to the bodyshop.
So everything set to install the spoiler completely? Almost. As you can see, the brackets on my worn out spoilers are quite bent.
Some were even completely missing or "fixed" with a bit of backyard-engineering:
After I bent all the existing brackets in a more-or-less correct position and installed it back on the car, i have to admit it looks quite good, even though it's still just a completely temporary mock up.
I also had my replica US-spec turn signals installed (I will look for some good OEM-ones, as these lack the mandatory E-stamps on it).
Which made the iconic, but also a bit ugly, EU-spec turn signals obsolete. Even though I don't think the look is too bad, I always have the feeling that they were just slapped on the car in a hurry, and are held on the bumper with only one nut, so they always look a bit off in their position and are hard to get it right (see previous photo). So I had them removed.
The US / Japan spec turn signals always looked much sleeker to me, fully integrated under the bumper. Like intended from their designers. So for the moment, I'll stick to this setup. But I might change back to full EU-spec, if required. During this work, I was also able to fix two previous issues with the front bumper alignment, which is great too. From my point of view, the front-end (everything in front of the radiator support) is completed now. Next I'll focus on some other points. My 2-do list is getting smaller, and I'm happy with every task I can check off.
I expect DHL ringing on my door with some nice stuff from Japan every moment, and i have some more things on the way here, so expect another update soon.
