Hey guys. This is my 1976 Datsun 240k. Has spent the last year slowly getting some new stainless extractors and exhaust.
Currently getting some love with my brother to get it trucked up to FNQ.
https://www.classiczcars.com/forums/topic/44012-mr-loud-and-smelly/
  • 7 months later...
So finally moved back to Brisbane area and had some time to work on the 240k.
When I came down, the car was running. Had to lend someone my pertronix setup for a few weeks, upon
reinstallation, the carbs started leaking, pulled them apart, cleaned them out but lost a washer somewhere. Tried
making a new one which worked for a little while until it backfired and then back to square one. Might need to rebuild them
again. While it wasn't running I decided to started pulling out the interior to inspect and clean. The car had been sitting for a while
previously and acquired a not so nice amount of rat poo and mud wasp nests in the heater system, dash, floor and glove box :s. So cleaned
as much as I could see and get too. Initially i was going to keep the car carbie but decided i wanted a bit reliability and have gone
down the efi path.
I ordered this a while ago through streeter
<a href="http://smg.photobucket.com/user/ill-minded/media/Cars/YonMeri/DSC_5076.jpg.html" target="_blank"><img src="http://img.photobucket.com/albums/v511/ill-minded/Cars/YonMeri/DSC_5076.jpg" border="0" alt=" photo DSC_5076.jpg"/></a>
Got to dummying up the throttle body setup with the supplied manifold but ended up fouling on the headers.
So either the headers need modifying or possibly angling the manifold to help clear it. Still not sure the way to go, might even
be a combo of both. The manifold is pretty rough, so may end up having to get something longer.
<a href="http://s164.photobucket.com/user/wingfay/media/DSC_0940.jpg.html" target="_blank"><img src="http://i164.photobucket.com/albums/u13/wingfay/DSC_0940.jpg" border="0" alt=" photo DSC_0940.jpg"/></a>
<a href="http://s164.photobucket.com/user/wingfay/media/DSC_0944.jpg.html" target="_blank"><img src="http://i164.photobucket.com/albums/u13/wingfay/DSC_0944.jpg" border="0" alt=" photo DSC_0944.jpg"/></a>
Am planning on using megasquirt with a MSD 6AL. So ordered a kit and put it together. Still needs a bit of wire tidying.
<a href="http://s164.photobucket.com/user/wingfay/media/DSC_0938.jpg.html" target="_blank"><img src="http://i164.photobucket.com/albums/u13/wingfay/DSC_0938.jpg" border="0" alt=" photo DSC_0938.jpg"/></a>
Have sent away a L28 block for testing to see if its worth putting money into. Also ordered some new fuel lines,
surge tank and pump to keep it all flowing nicely.
Removed the fan and need to go to the wreckers and sort out a thermofan/shroud setup to suit.
My brother is sorting out getting a crank trigger made up that will bolt in directly.
<a href="http://smg.photobucket.com/user/ill-minded/media/Cars/YonMeri/DSC_5417_zps4b4d14ee.jpg.html" target="_blank"><img src="http://img.photobucket.com/albums/v511/ill-minded/Cars/YonMeri/DSC_5417_zps4b4d14ee.jpg" border="0" alt=" photo DSC_5417_zps4b4d14ee.jpg"/></a>
Have pulled out the wiring loom in the engine bay to see if I can remove anything redundant and upgrade the wires to the headlights.
So am waiting on a few things, hopefully they arrive soonish so I can get the current engine running on the efi setup
